exporting a sketchup model with some vray materials applied to another pc
  • exporting a sketchup model with some vray materials applied to another pc
    hi
    i have a question.
    i'm working on my pc, but i have a most powerfull pc in my office to render..
    how can i export my model with my vray materials applied to my office pc without losing the materials setup..
    i mean in my computer i render the model with some brushed metal and black leather..but when i'm going to my office and try to render the same model with the same sketchup scene. the brushed metal doesn't exist anymore... and the leather neither..
    i hope somebody can help me .. or just say me.. :-\no men.. theres no solution for your problem u have to reapply all the materials.. :'(
    Re: exporting a sketchup model with some vray materials applied to another pc
    Hello Rauango
    If you put your scene, textures, and materials into the same folder and move it all together it will normally keep you from having to reapply all of it later.
    There is also this:
    http://forum.asgvis.com/index.php?topic=5902.0
      oke what you do is go to your system rollout in options of vray and then you check "distribute rendering" and check "send to shared folder" (you're faking a render farm with all the materials in 1 map) so you click render and wait untill vray processed the scene. Now all the vray materials are in the map you chose and yoiu can copy that map to your computer at work, load one material and all materials should load automaticly after this. not 100% sure if I explained correctly.
      remon_v
