Double your render cores (test run)
  • Double your render cores (test run)
    Hi guys
    My friend has accidently find this out for sketchup
    Take your machine (we have a quad core) and open Dr spawner
    then look up your machines ip address.
    Put on distributed rendering and add only your machine.
    We have picked up that the address works for only once...so you cant add 3 or more times the same ip address.
    Then fire up a render.
    You ll notice instead of having 4 cores rendering for you...you have suddenly 8 cores. tadaa...not sure how much faster it is..maybe it help.
    Re: Double your render cores
    I dont see how this could help really. The CPU is already maxed out at 100%. It sounds like the "Idea" of hyperthreading but without actually having hyperthreading. Have you run any time test to check your theory?
    John Harvey<br />Intern Architect<br />Digital Design and Fabrication<br />http://jrharveyarchportfolio.blogspot.com/
      yea it seems like time test is around the same time...
      i wonder how it would work on an I7 and if it would make any difference
        Re: Double your render cores (test run)
        I'll test this tonight with my new i7 ;D
          Just tested it on a simple scene. Without DR, it took about 37 secs. With it on, it took longer... around 40 secs. Presumably due to Vray spending some time trying to locate the supposed render nodes.
          But it did double the number of render boxes (8 to 16) but definitely did not speed anything up.
            ha ha now we know.
            Thanx for the tests ^^)
              you guys are silly ;D
              Devin Kendig
              Developer
              Chaos Group
