greyscaling?
  • greyscaling?
    To create a grey scale bitmap in photoshop I have been selecting image -> adjustments -> black and white.
    Is this the correct way to create a grey scale bitmap for bump mapping. I just want to make sure I'm using the correct technique before I proceed to make anymore bumpmaps.
    Thank you
    Re: greyscaling?
    There's many ways to convert a colour image to grayscale in Photoshop, all useful for creating bumpmaps. Image>Adjustments>Desaturate is probably the most commonly used.
    SU 2018 + VfSU 4.0
      Re: greyscaling?
      I usually turn down the saturation and then adjust either Contrast/Brightness or Levels to the point where I have the level of detail in the bump map as I want.
        Re: greyscaling?
        Ah righty.... thank you. Just want to make sure I'm doing things in the right manner
          Re: greyscaling?
          The sharpest way to do this is by using a gradient map on your image. First step is to make sure your colors are on default by pressing shift-D. then on the layers tab go to "new adjustment layer" and pick gradient map. Then just flatten and save as. It will be better than just desaturating the Pix.
            Re: greyscaling?
            thank you very much, that was simple enough. Do these different methods of greyscaling really make a great deal of difference to the overall bumpmap? if so can anybody explain why?
              Re: greyscaling?
              A bumpmap isn't simply a greyscale version of the diffuse map. You wan't to pick out the details you want to appeared raised. There isn't *one* correct way of doing it. It depends texture to texture.
                Re: greyscaling?
                try gimp (free) and go to filers > map > bumpmap and play around with the settings a bit. U stille need to desature first but that easy in gimp
