Looks like you've activated the Depth of Field function in the camera settings- that's probably some very blurred geometry in the foreground obscuring the scene.
Looking at your first image again one thing looks very suspect- the reflections on the left side of the image. It looks like you're looking through a sheet of glass into the interior and the exterior is being reflected in it. If this is the case then you've probably done something to VfSU's camera settings (e.g. FoV) so the clipping plane in VfSU is behind that of SU. If you move the camera forward does the grey portion disappear? It's usually not a good idea to put a camera hard back up against a surface, especially if it's glass.
BTW it's not good practice to post renders in png format on forums- they're a complete waste of bandwidth. Your 1.2Mb png image is only 125kb as jpg.
I changed the image, Jackson.
What you said might be right....VfSU might be clipping it behind SU. I am trying to render after hiding that portioon of glass and steel. And now my SU keeps crashing giving me 'No space in TEMP folder' error!!!
Yep, but I meant to convert your own images to jpgs before posting, not to delete yours and insert a completely different image instead. Now when anyone views this thread it doesn't make sense anymore.
