Render floorplans
  • Render floorplans
    Hello, I am trying to render floorplan, but I dont know how to render floorplan with dimensions. My second problem is that I am using for rendering floorplan standard camera and paralel view, but my final image is too bright. Can you help me?
    0
    Render with standard camera is too bright.
    0%
    0
    How to render dimensions?
    0%
    0
    Re: Render floorplans
    post an image of what you are working with so that people can get a better idea of how to help
      With brightness I don´t have problem anymore, but I don´t know how to render image with dimensions.
        You can't render dimensions. You have to add that later in post.
          The best way is to render the image using a scene at a set resolution, then turn off all layers except that with text/dimensions and then export that from SU with the same resolution as your image as a png and then using an image editing program lay the exported dimensions on top of your rendering
            how would you guys simulate the parallel projection view of Sketchup (ideal for a "floorplan rendering") at VRAY?
              Doesn't that work if you turn of physical camera?
                since i alway use physical cam in my renders (for ease of control of exposure levels), just change the field of view in skp by using the zoom tool and type "0" (zero). you'll notice that the view will be similar to a plan view. then, just "add scene" to save the scene file. this will enable vray to render the scene in parallel perspective. btw, this also works in elevations. hope this info helps.
                  On a different note, can I ask why you want to render a floorplan with dimensions? Plans with dimensions are usually used for final drawings done in AutoCAD or Vectorworks, etc.
                  Presumably you want a pretty image of a floorplan which shows the layout of your building, since you are rendering it. I can only presume you are using the image for a presentational purposes. Adding dimensions to it would probably just make things messy and is probably unnecessary information.
                  Just my two pence
                    u are my new god chavinskee. Perfect!
