Image Sampler Adaptive DMC Noise Threshold vs DMC Sampler DMC Noise Threshold ?
  • Image Sampler Adaptive DMC Noise Threshold vs DMC Sampler DMC Noise Threshold ?
    In the Image Sampler when you choose Adaptice DMC you have a Noise Threshold field.
    In the DMC Sampler there is also a Noise Threshold field.
    In the V-Ray manual there is no Noise Threshold mentioned: http://www.spot3d.com/vray/help/150R...mpler.htm#admc
    But there is a Color Threshold you can enable. If it's not ticked it uses the DMC Sampler settings to determine how many samples are needed.
    http://www.spot3d.com/vray/help/150R...dmc.htm#params
    1. So how does this work in VfSU?
    2. Is the Noise Threshold in VfSU's Image Sampler ADMC in reality the Color Threshold that's always set to on?
    3. If not, what is it? What's the difference in VfSU and the V-Ray for Max version?
    4. If I use ADMC, will the DMC Sampler Noise Threshold affect my Image sampler?
