yellow squares appearing in my render?
  • yellow squares appearing in my render?
    what are those yellow squares appearing in my render? what is the cause?
    Re: yellow squares appearing in my render?
    Maybe an image to illustrate your problem! then we know what you are talking about!
    Dutch tutorials for Sketchup and V-ray: Proseduction.nl<br /><br />And although i have some tutorials i still am learning!
      it often helps to be able to share video and images to illustrate what you're talking about, especially since our users speak different languages. I suggest flickr, photobucket, or Jing. Jing lets you record video as you recreate an issue, which can prove to be quite helpful
      http://www.jingproject.com/
      Devin Kendig
      Developer
      Chaos Group
        this is the output of my render using physical camera, vray sun and sky, IR and LC.
        IR has min-3 and max 0, LC has 2000subdvs
        there are yellow squares after the render. i indicated it on this image below.
        can you see them? its a pale yellow.
        resolution is 1600x700
          are you using DR?
          Devin Kendig
          Developer
          Chaos Group
            (Distributed Rendering?)
            -Intel Core i7-930-<br />-12GB DDR3 SDRAM-<br />-ATI Radeon HD5970-<br />-1TB Hard Drive-
              yes. i used distributed rendering. DR caused this?
                Yes, than it is a material distributing problem or lag in the connection between the multiple computers. I had the same problem a time ago. I connected the multiple computers by cable instead of wifi and i thought that solved the problem, or you maybe can try something with the distributed renderings settings, but i am not an expert! maybe someone else can tell you something about the settings!
                  Also you should have the same version of DR in all of the machine.
                    i connected it via cable and yes th DRspawner has the same version.
                    maybe its because i used the slave computer? when i rendered this image i am also using the slave computer for some 3d.
