unable to download
  • #16
    Re: unable to download
    Yep, im pretty sure, it was the path to sketchup 7...otherwise it wouldnt continue the installation process anyway...
    • #17
      take a look in side of your sketchup plugins directory, there should be a file in there called vfs.rb if the installation found your SketchUp installation properly.
      Devin Kendig
      Developer
      Chaos Group
      • #18
        that file is inside Plugin folder! when i click on Model-preferences, the vray is in the list of extensions, but there's nothing on the working screen, buttons or toolbars, i just cant use vray, it's so weird....it's driving me nuts
        During the installation, the license screen i've read about doesnt appear also
        • #19
          Yeah, a licensing dialog didn't show because you already had a valid license on that machine I'm guessing. What about the plugins menu? If you click the plugins menu, is there an option for V-Ray for SketchUp?
          Devin Kendig
          Developer
          Chaos Group
          • #20
            I do have a valid license on this computer...but still i cant see the new vray toolbar anywhere...there's no mention of it on the plugin menu...only in the preferences - extensions list..
            i've installed on another computer and still didnt get any results. Im losing hope in here guys =(
            But thanks anyway =)
            • #21
              Should see it in View>>Tools>>Vray for sketchup. Maybe untick that, restart sketchup and retick it see if it pops up.
              Failing that, change your desktop resolution to something smaller then launch sketchup. Quit back out of it then resize your desktop and restart your sketchup again and the toolbar may reappear. Resizing the desktop always screws around with my toolbar locations so maybe it will return. Worth a shot anyway.
              • #22
                still the same problem...although the vfs.rb file is inside the plugins folder, there's nothing inside the plugins menu when i open sketchup. i guess this bug is more serious than i thought, maybe something that asgvis should worry about
                • #23
                  Here's a strange bug: when i try to install the new vray on sketchup 6, it shows this error dialog when i open sketchup 6:
                  No such file to load -- R2P.rbError Loading File vfs.rb
                  Maybe with sketchup 7 it's happening the same thing, i dont know.
                  Anyone?
                  • #24
                    Well I use SU6 and it works fine, I dont know about Su7.
                    Did you install as administrator etc?
                    • #25
                      Yeah...i've tried to install on SU7 and SU6....and none of them seems to work out
                      i dont see any vray toolbar, the vfs.rb file apparently is not working properly
                      • #26
                        I'm not sure what else to suggest, maybe one of the admins can do a teamview session with you or something?
                        • #27
                          yeah, i hope someone from asgvis knows how to fix that..
                          But thanks a lot man!
                          • #28
                            The error message you got that says that it can't find R2P.rb, after trying to load vfs.rb. vfs.rb is the file that sets up V-Ray for SketchUp as an extension (this is something new we do so you can enable or disable our plugin from the SketchUp preference's extensions section. So the extension starts to load, it immediately tries to load R2P.rb, which depending on your OS, could be in a couple different places. So what OS are you using? is it XP, Vista, Win7, OSX 10.4, OSX 10.5, OSX 10.6?
                            Devin Kendig
                            Developer
                            Chaos Group
                            • #29
                              Im using windows XP
                              • #30
                                Actually, ricky licky started a new thread about the toolbars and stuff not showing, so if anyone has the same issue as what ricky licky mentioned here, post in his thread instead of this one. Here's the link: http://forum.asgvis.com/index.php?topic=7477.0
                                Devin Kendig
                                Developer
                                Chaos Group
