Try by inverting the mapping on the perpendicular slot. The bug is that the mapping on the fresnel perpendicular slot seem to be inverted. Where should be the black color is the white and vice-verse.
Best
doesn't seem to be inverted in all cases though. Right?
Before we resolved the issue everything seem to be inverted. Some time the amount of black and white in the mapping are very similar giving you the appearance that is working fine.
We solve that issue some build ago.
at what value should I set bump multipier for this example? 0.05?
Yes, you'd set the bump map multiplier to 0.05.
For most of the multipliers, 1.00 = 100%. One exception is the multiplier for displacement. In that case, a multiplier of 1 = 1 inch.
I am currently using V-Ray 1.49.01.
SketchUp 8.0.11752
Windows 7 Professional-64 bit
Intel(R) Core(TM) i5 K655 @ 3.20GHz
8.00GB of RAM, 1.2TB Hard Drive
