Features Removed in VfS 1.48.66
  • Features Removed in VfS 1.48.66
    • There are few features that were included in previous VfS (1.05.30) and weren't included in the new version.
      For instance:
      • Low Thread Priority
      • Showing how many pre passes has left before rendering - f.e "pre pass 2/3" in the progress window
      I would like to ask the developers to include those features in the next VfS update/release.
      Edit:
      • Key Shortcuts enabled during render
      • Compact UI/layout menus
      • Ability to see materials arranged alphabetically- Material editor window
      • Specification of the version number (e.g. 1.48.66 - Options>about)
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
    Re: Features Removed in VfS 1.48.66
    +1
      +1
      SU 2018 + VfSU 4.0
        +1
          Added few more removed features. Main post updated.
          www.Top3Dstudio.com
          SU 8
          VfS 1.48.89
          Win 7 64-bit
            Also I noticed that in the new VfS there is no specification of the version number (e.g. 1.48.66)
            and in previous versions it was listed under Options>about
            www.Top3Dstudio.com
            SU 8
            VfS 1.48.89
            Win 7 64-bit
              You find it in Model->Preferences->Extensions
                "-Key Shortcuts enabled during render"
                that explains why i cannot use su shortcuts.
                I also have a difficulty arranging the layers of a material(diffuse,reflective, etc)
                does the UI is a bit slow? or is that normal?
                  Thanks, found it. I'll edit the post
                  Sometimes it's lagging but it happens rarely.
                  www.Top3Dstudio.com
                  SU 8
                  VfS 1.48.89
                  Win 7 64-bit
                    +1
                      latest update has resolved some of these issues:
                      Low Thread Priority
                      Devin Kendig
                      Developer
                      Chaos Group
                        Just to ask the question, is there an advantage to not showing the number of prepasses remaining? I know it's a detail, but I would generally like to see more information instead of less information (unless it cause problems or slows the system down--of course).
                        http://wworks.carbonmade.com
                          progress window was causing a slowdown, we have had higher priority on other bug fixes, we plan on bringing it back once we figure out a way to do it without slowing everything down.
                          Devin Kendig
                          Developer
                          Chaos Group
