a different displacement problem
  • a different displacement problem
    I have been having issues creating displacements on complex surfaces. Squares and such work fine. I had a streaking problem somewhat like this before but now the displacement is only appearing in certain poly's within the surface.
    Here's a render I did a few weeks back that had streaking, but the displacement showed up everywhere it was supposed to:
    Re: a different displacement problem
    As I've already answered to your problem here:http://forum.asgvis.com/index.php?to...45848#msg45848
    The issue you're having is not enough subdivisions. when you have a large plane/face vray needs enough subdivisions to do the displacement.
    Just divide your plane (preferred to triangles).
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      About how many subdivisions? That is 2048, I started at 128 and it did not make any discernable difference.
        what I meant is that you need to divide the surface manually (via SU)
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
