Vray doesnt render the object in a position that i adjusted.
  • Vray doesnt render the object in a position that i adjusted.
    hey guys . i am new to Vray for sketchup. i tried to render the object.
    but Vray doesnt render the object in a "size" and "positon" that i adjusted
    in sketchup. it always turned out to be in a further distance.
    dont know what did i do wrong. pls help.. thx a lot.
    Re: Vray doesnt render the object in a position that i adjusted.
    Hi Yuyisxs,
    What vfs do you use?
    can you post screen shots: the su view and the render outcome.
    Can it be an zoom issue, where you see the object in SU close and when you render that object appears to be farther?
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      . . . . also, if the SU view is in a parallel projection, vray will render the nearest version to this in perspective view - usually making the model appear smaller. Also I always set the required view as a SU 'scene'.
      David
      Sketchup 2015
      Vray version 2.00
      www.davidcauldwell.co.uk
