Hi
I normally use a programme called "Image convertor Plus" to convert EXR images to PNG (Alpha channel)
This has worked really well. Untill I tried to convert any EXR file over 400mb. The progamme just crashes.
So I downloaded the openEXR pluggin for PS CS3. I havent been able to get the alpha channel to come through.
So I end up with no transparent background or transparency through glassed areas. I get a white ghost out line aswell.
I see you have to play around with the exposure and gamma settings. It was really easy using "Image convertor Plus"
It would just convert the EXR to PNG (Alpha channel) with out changing anything. No ghosting no changing settings.
But it just crashes if the file is to big.
What do other people use. Or am I missing something?
PROBLEM WITH GHOSTING (WHITE OUTLINE) SOLVED
When I was importing the EXR into PS I was ticking the Un-Premultiply option in EXR Import settings.
Attached is a screen shot
