Render on 6 Core Processor
  • Render on 6 Core Processor
    Hello,
    I just recently upgraded my machine and am now running on an intel i7 980x .. 6x 3.33 ...
    I am running windows 7 64bit.
    I have noticed while rendering a scene that the CPU usage never goes beyond 35-40% ...
    Is there anyway I could make use of the full CPU power?
    Thanks in advance..
    Re: Render on 6 Core Processor
    there isn't a setting you can set that will effect this, no.
    Devin Kendig
    Developer
    Chaos Group
      Is this limited by Sketchup or Vray?
        it shouldn't be limited at all by either, so it's really hard to say. Either way, you guys can't change a setting in our program to "fix" it.
        Devin Kendig
        Developer
        Chaos Group
          Doesnt the light cache "passes" setting achieve this dkendig?
          If I stick this setting to "8" it uses all 8 of my cores at 100%.
            No, that value isn't designed to control the amount of your cpu that is used.
            Documentation on Light Cache
            Number of passes - the light cache is computed in several passes, which are then combined into the final light cache. Each pass is rendered in a separate thread independently of the other passes. This ensures that the light cache is consistent across computers with different number of CPUs. In general, a light cache computed with smaller number of passes may be less noisy than a light cache computed with more passes, for the same number of samples; however small number of passes cannot be distributed effectively across several threads. For single-processor non-hyperthreading machines, the number of passes can be set to 1 for best results.
            There isn't a CPU throttling option of any sort, that's what I was trying to say. If certain values being set, make v-ray use more cpu than other values, it's should only be because the render is more complicated. At least as far as I know. The only thing that would really make any difference for cpu usage would be the low thread priority option in the Global Switches. That should really only effect performance when you are multitasking though.
            Devin Kendig
            Developer
            Chaos Group
              Hmmm if I remember correctly, if I set my passes number to less than 8, then I get a warning in the info box that all 8 cpus arent being used.
              So in theory what number should I actually have in the passes for an 8 core cpu?
                Your guess is as good as mine. All I know is that V-Ray should be taking advantage of as much CPU horsepower as it possibly can, so there shouldn't be a setting that allows you to control how much CPU is being used, because it should be using as much as possible whenever it can. Fernando might have a better answer for you, he's our trainer.
                Devin Kendig
                Developer
                Chaos Group
                  As far as I know Sketchup it self is still just single core. That's pretty stupid but doesn't affect rendering with V-Ray. V-Ray uses 100% overhere. If I remember correctly from a tutorial the number of passes should be equal to your number of cores. But I can't remember where I heard it.
                  V-Ray 6 Beta | Intel i9 9900K | 64GB | 1x 512GB EVO 970 Pro SSD | 1x 1TB Kingston Nvme | 1x 4TB Lexar Nvme | 2x 6TB SATA | 1x 4TB SATA | 1x RTX 4090 24GB + 1x RTX 3090 24GB
                    You should use the number of how many core you have in your PC
                    This is what number of passes does. Y
                      is the cpu not being fully utilized during other parts of the render, other than during the light cache calculation?
                      Devin Kendig
                      Developer
                      Chaos Group
                        Should use all cores during IR and DMC. Least what it does on my quad-cores.
