problem with mood
  • problem with mood
    hello
    i've been trying to add some mood to my exterior renders, and discovered i could achieve it by adding a color at the environment slot, and check "default lights" to add the sun. (i used to add sun in the environment slot)
    but by doing this, i don't have control over the sun size and power.
    sorry my bad english. thanks.
    Re: problem with mood
    is my english so hard to understand?
      The Default Light is actually the sun. if you want to control the default light place the TexSky in the GI color, then adjust the sun parameter. this will also change the parameter for the default light (that is the sun). Then take out the "TexSky" from the GI Color and use your preview setting. The default light will still getting the setting that you had in the GI color "TexSky".
      Best
        remember to check it out also the location of your model and the time/day of your shadows in Sketchup
