HOW?
  • HOW?
    i would love to know how do i render a few scenes automatically one after the other in sketchup, sometimes i have a few scenes set up to render but i leave it overnight. i want vray to render all the scenes so when i wake up all scenes will be done, is this possible in vray? sometimes its just like 3 scenes, how do i do this?
    Re: HOW?
    I would like to know it too.
    http://www.vizualizaceschodiste.mypage.cz/
      Re: HOW?
      Render as an animation with 1 frame per second? That's the easiest way I think? Only problem is that your camerasettings etc. are the same for every render...
      Regards,
      Peter
      AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
        Re: HOW?
        so now am gona hav to get to kno abt animations,lol, i was afraid of that, where do i start?
          Re: HOW?
          hi mr. senator, please try this: (i have it somewhere in this forum, but i can't source it.. ???)
          Step 1
          Window > model info > animation.
          1.1. Enable scene transitions
          1.2. Set scene transition to 1 second
          1.3. Set scene delay to 0 seconds
          Step 2
          VRay for sketchup render options > Output
          2.1 Pick preset or specify output size
          2.2 Under the Render Output sub option, enable 'save file' and specify output directory and file type. (VRay can not render out a move file but rather a series of stills which can be combined into an animation in video software if required)
          2.3 Under the Animation sub option tick the 'on' box and choose a 'Custom' frame rate specifying the FPS value as 1. This will effectively render out 1 frame per second which when combined with the sketchup settings from Step 1 above will produce 1 frame (still image) per sketchup scene
          Goodluck,
            Re: HOW?
            amazing!!! i ran some tests, works perfectly just as you said, thanks alot vidy!!
              Re: HOW?
              you're welcome mr.senator, actually i just passed the information,
              me too grateful to someone who first time posted it
              regards,
                Re: HOW?
                I often run several instances of Sketchup with the different scenes and render all of them at the same time. This way, I can have different settings for Vray per image. Whereas rendering as an animation, you can only use one setting type.
                  Re: HOW?
                  I wouldn't recommend running multiple instances of SketchUp on Mac though, because they do some screwy multiple document stuff that messes up our material editor.
                  Devin Kendig
                  Developer
                  Chaos Group
