Parallel Projection - FAIL
  • Parallel Projection - FAIL
    We have a project, which we are doing a rendering on that needs to be in parallel projection not perspective.
    All of the perspective views render properly. When they are set to Parallel Projection, they show up as though the camera is zoomed in very close on a particular material.
    Is there some way that you need to setup a view differently in order for the Parallel Projections to work?
    Thankyou in advance
    Re: Parallel Projection - FAIL
    I've never actually tried it in Vray but have you tried setting the perspective to like 1deg or something very close-to but not quite parallel?
      click override FOV and then type in 1 degree
        you can do it in sketchup.
        click in the zoom tool, then type 1 then enter.
        the default is 35 (degrees)
        you may also put higher values for more dramatic scenes.
