building light cache never pass
  • building light cache never pass
    Hi i have scene with vray 1.05 everything fine but its not passing building light cache its stuck there i was wait for long time still same any advice what can i do? Thanks.
    www.jackscabana.co.uk
    Re: building light cache never pass
    so no body knows? whats the light cache settings needs to be for normal qualty render thanks.
      do you get a "(null) bitmap" line when building the light cache?
        Hey there,
        I'm a VfR-User, so I can't actually help you in giving you the correct values.
        There are many possible reasons why your rendering fails.
        Maybe there are bad objects in the scene, maybe your hardware runs at its limits or beyond, maybe a material isn't set up correctly, or it's a number in your settings that makes for an invalid process in the prepass.
        Have you already tried to download some of the VfSU presets from here?
        Just look and learn from those files.
        Good luck!
        Cheers,
        Matt
          I have 67 different render visopt settings pretty much most of it stuck do you have any so that i can try on as well. I have that problem from light cache only because i tried to lower the settings in light cache settings its start making it i think only problem is value in light cache too high but i don’t have that much experience to change them.
          here is setting i am trying on
          http://www.2shared.com/file/A0f-tJW0/setting.html
          Thanks
            No no null map just nothing no error stuck with black render screen like that.
              settings depend on the scene, there is no standard setting for everyone.
              i highly recommend you look at these video tutorials:
              http://software.asgvis.com/index.php...182&Itemid=480
              particularly the ones by jorge barrero. They go through basic settings and what they do, very very useful, i learnt enough from them to now always make my own settings.
