greater yield
  • greater yield
    Hello, it would want to know like obtaining best quality in the render one of the images, this is by the configuration of the scene or the typical of the computer? If it is by the computer, as they are the typical that they recommend? thank you very much. -
    Re: greater yield
    In my opinion the computer is only the tool. To get the best rendered image it takes more of a combination of good modelling and good textures. The only thing the computer will change is most likely the time to produce these renders. And if you have more than one computer available you can use the others as a render farm to help speed up your results.
    Hope that helps.
    Rob
