Not able to use Transparancy maps in VRayLinkedMtl's?
  • Not able to use Transparancy maps in VRayLinkedMtl's?
    Hi, I'm having trouble with Transparancy maps in VRayLinkedMtl's. The alhpa maps keep disappearing! I create a material in SU (with png texture), scale/map it etc., create a VRayLinkedMtl, link it to the proper SU material, add a Transparancy map, Update Preview but there's no transparancy in the preview or render. When I check the Transparancy map in the material again, the capital M changed back to a normal m!? What's going on?
    The transparancy map does work in a normal VRayMtl but its a tedious work to get it to scale and map properly. That's what the Linked material is for right?
    Re: Not able to use Transparancy maps in VRayLinkedMtl's?
    that material type doesn't exist anymore. You're still using the 1.0 release? Did you know that it's free to update to the latest version?
    Devin Kendig
    Developer
    Chaos Group
      Ok thanks!
