color problems
  • color problems
    Hi guys,
    I have this kind of problem and I can´t understand how to avoid it. I hope someone can help me!
    In my screen the rendering looks perfect as this one:
    but
    when I am going to print, in some areas I can see some weird colors... somehow the gradients color on the walls are not soft. (thery are just white 244 244 244)
    It is very difficult to explain how it looks like...
    so I made here another screenshot, using photoshop I did some very HIGH contrasts, but it gives the idea what I am talking about...
    any ides or suggestions?
    thank you!
    serra
    p.s.
    It is not a printer problem, because I am using a professional photo-lab.
    Re: color problems
    Things you might double-check:
    Convert the file to CMYK before printing
    Save in a 16bit or higher mode/format
    If that doesn't work, try to calibrate your monitor to your print house's printer. Sometimes they can help.
    What kind of printer are they using?
    emil mertzel
    vray4rhinoWiki
    Lookinglass Architecture and Design
      Re: color problems
      Hi!
      thx Emil
      but
      I am 100% sure that is not a printer-issue because if I am looking (from bottom to the top) at my lcd-screen I can already see the wired color gradients...
      any other helps?!
      thx
        Re: color problems
        p.s.
        can I save from vray 32bit format image?
        No?
        yes?
        how?
          Re: color problems
          the hdr format is 32 bit. not sure about exr but i would bet it is.
          if you're seeing it on screen, do you see it in the v-ray frame buffer or just when you open it in your image editor?
          emil mertzel
          vray4rhinoWiki
            Re: color problems
            already in the v-ray buffer
              Re: color problems
              I would otherwise guess that it's a monitor problem, but it's showing when you print so it's in the image. Saving 32bit probably won't help if it's in the VFB. What color mapping are you using?
              Another way to diagnose this is to go back to settings that you know will work - presumably you aren't getting this on other renderings?
              edit: also, what rendering engines and color mapping are you using? i don't see any GI shadows around the stool, are you using Light Cache? sometimes you can get a similar artifact happening with light cache if the sample size is too large...
              emil mertzel
              vray4rhinoWiki
                Re: color problems
                Hi Emil,
                here my settings:
                thank you
                  Re: color problems
                  Try using DMC instead of LC for secondary engine and see if the effect goes away. The scene will probably get a little darker, don't worry too much, just see if the colors smooth out.
                  emil mertzel
                  vray4rhinoWiki
                    Re: color problems
                    mmh nope,
                    it is not getting better....
                      Re: color problems
                      sent you a PM, check your inbox
                      emil mertzel
                      vray4rhinoWiki
                        Re: color problems
                        So Serra and I worked this out offline, and thought we'd post what came of it in case it's useful to anyone else. The problem turned out to be in the Irradiance Map settings, the HSph.Subdivs and especially Samples were set too low, so the quality of the blend between sample areas was poor. I've never seen a low sample value produce this effect before, just blotches, so news to me.
                        emil mertzel
                        vray4rhinoWiki
