please somebody tell me how to do walk trough in sketch up...thank you...
walktrough
Re: walktrough
There are multiple ways to do a walkthrough. You can do it by makes scenes and check if they don't go through walls at some points by playing the scenes over and over again. I use this method. When the corners are tight you need to place some more scenes to get a nice turn.
When all scenes are placed and you want to render use the output tab in options of vray and select animation. There you select the amount of frames per second. Remember for a nice fluent animation you need 23 fps minimal per second.
Another way is using flypath.rb you can find it on smustard.com for me it is a long time i did it like that. So you need to check the manual for that.Dutch tutorials for Sketchup and V-ray: Proseduction.nl<br /><br />And although i have some tutorials i still am learning!
