Removing Vray materials back to default
  • Removing Vray materials back to default
    Hiya,
    I'm using Vray V. 01.48.89.
    I have been modelling a building for some days now and have added loads of materials onto my model. I now would like to remove all those materials and start over. Is there anyway to delete all material so that your material editor is left with Default_VRay_Material?
    Another thing I have tried to purge all unused material but nothing happened. I was under the impression that it would remove unused material from Material Editor.
    Lastly, when I remove a material it just moves to the bottom of the material editor without been deleted.
    Any help would be appreciated greatly.
    Thx
    Re: Removing Vray materials back to default
    sCheck out this remove materials plugin
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      Thx, I'll try it out this evening.
        Yes - if no materials where purged, the it means they are still in use somewhere. Beware that edges has materials as well, but by default in SU all edges looks black. I find this to be a big cause of left-over materials in models as people aren't aware they apply materials to edges.
        My Remove Materials plugin will let you remove materials from only edges if you like.
          Hi ThomThom,
          I tried your plugin last night and it worked well. Thanks, keep on writing these useful programs.
          Best Regards,
          Christian
