no control over IES lights
  • no control over IES lights
    Hi, hopefully someone can help.
    No matter what I do, I cannot control IES light intensity - they always make my renders white!
    I have an interior scene (by which I mean everything including the camera is in a box) I edit the IES light, select a .ies file, turn off my physical camera and sun as this tutorial suggests:-
    http://www.sketchupartists.org/tutor...-for-sketchup/
    When I hit render, its almost all white. Even if I put minus 10000000 in the power, no change.
    The only thing i'm not sure about is if I actually have turned the sun off - I go to 'environment', click the little 'm' and set the 'texsky' to 'none'.
    Any help will be greatly appreciated.
    Cheers, Matt.
    Re: no control over IES lights
    I have the same problem too.... :'( :'( :'( :'(
    plzzzzz..... help us...
    windows 7 x64, vray 1.48.98 & sketchup 8 pro....
    THANK u n advance........
      you need to control your physical camera. Try adjusting the f-number and iso. I dont think minus values have any effect on lights and i think its the same as a value of 0. If you want the sun off, just set it to a night time value in SU. Hope that helps, best of luck
