How can I get these kind of image? which are the settings of the camera to get that type of view? .. i saw a video to hide the ceiling with a 2side material but don't explain the settings of the camera. If someone could help me. Thanks
the trick is to actually turn the phisical camera off... the camera gives you the perspective mode. the illumination shall come from rectangular or omnilights.
that image, by the waym seems to be made in photoshop... so dont break your mind that hard
try keeping de physical camera on... but, use the Field Of View to modify the perspective... whit this tool you can give more perspective to the 3d model.. or you can give any.
i've try it in my last project and it worked perfect....
It's been posted about before. If you go to plan view and set your sketchup perspective view FOV to 1.0 then fit all, you should have it close to straight. You can then go to your vray camera settings and increase your focal length to something like 2000 or 4000mm. You will still have a faint outline of the walls, but that's easy to mask out.
-Andy
