basic things to do for rendering
  • basic things to do for rendering
    helo. this may sound silly.. but i really hope to know what are the most basic steps to do for rendering in vsfu?
    and how much time do most of u need to render one view? is it one hour? bcoz for me, i have to wait like more than one hour just to get one view done.. mayb bcoz i put too many materials and detailing in my model.. i need ur opinion pls.. thanks
    Re: basic things to do for rendering
    hi,
    1. LIGHTS - Make sure your lights are correct 1st. For me, the lights
    setting come 1st, then material.
    2. MODEL - I know its a good for SU to use a low poly model, but if we
    talk about rendering, try use a hi-poly model coz it'll improve
    your realistic value (but as far as i know it shouldn't effect
    your rendering times)
    3. SETTING - Most of my images are rendered below 1hr. You don't have
    to use a high setting IF u get the same result as a low
    setting. Try to learn on how animation setting works, it will
    also gradually improved your rendering times!
    iZAN
    RizArcDesign.blogspot.com
    &quot;We provide three types of service: Quick, Cheap &amp; Good. You may select any two.<br />If it&#39;s Quick and Cheap, it won&#39;t be Good;<br />If it&#39;s Cheap and Good, it won&#39;t be Quick;<br />And if it&#39;s Good and Quick, it certainly won&#39;t be Cheap!&quot;
      hi...
      check this tutorial. i explained the basic steps, the most important thing you should do is have order. the model is the first thing, and by that i also mean that you should use layers to navigate easier... then go to the illumination, phisical camera, enviroment, artificial lights, move to material editing, adding layers to the materials, 2 sided materials, transparency, etc... and leave the settings to the end...
      http://software.asgvis.com/index.php...%22+series+now
      the time depends of the realism... a nice render with a regular machine shouldn't last more than 1 hour, but of course, you can work for weeks just to finish the model, or the light
      los campeones no nacen, se hacen...
