Distribuited Rendering Mac Vray Sketchup
  • Distribuited Rendering Mac Vray Sketchup
    hi,
    i would like to know how can install Distribuited Rendering.
    I' trying to follow the vray sketchup's manual but i not understand because after the install DR in the other computer, i can't find nothing about this, it is as if he had not installed anything. When i'm installing the DR, i select only the box "The distribuited rendering Spawner", it's correct or i also have to select "This will launch the license utility ....."? But if i can to do this, after how do i configure the license?
    thanks, and i hope i was clear.
    Re: Distribuited Rendering Mac Vray Sketchup
    Hellooooo?
      You installed DR on a computer, and it's as if nothing was installed? Run Applications/ASGVIS/RunDRSpawner
      Devin Kendig
      Developer
      Chaos Group
        My problem is on the mac client. when I go to install vray in the mac client, and i select only the box "The distribuited rendering Spawner" for install, after the installation in the mac client i can't find anything. The folder Asgvis there isn't, and then in the mac client can not find any folder. my question is why?I have to click also on the box "This will launch the license utility ....." when i'm installing the DR Spawner in client machine mac?
        In the Mac server i have no problems, there is all file and i can use correctly the vray programm.
          Hellllooooooo?
            So you said you have a server with the full version of Vray on it, and a client with the DR spawner program? Shouldnt it be the other way around? Having the DR Spawner on the Server and the full version of Vray on the Client computer? Correct me if I'm wrong.
            Rob
              There may be a bug in our installer that prevents us from doing a proper install when only installing the DR Spawner. Has anyone else had this issue? Allgabrio, if you need a response faster, I recommend contacting our support department. The forums are just where users can share with each other for the most part, we don't have any staff that regularly answers questions on here. We all just kind of pitch in when we get a minute.
              Devin Kendig
              Developer
              Chaos Group
