It's opening another instance of the texture editor, because you're clicking on a texture map button for Color Offset. Did you want to offset the color?... If you're using the texBitmap texture, typically the only thing you really need to worry about, is choosing the file you want to use. That would be the File parameter, no the Color Offset parameter.
