error message
  • error message
    i'm encountering a message when i try to render that says
    "we have encountered error(s) while trying to render. please check the error log for more detail."
    This error just starting happening out of the blue after i restarted my machine. i am running skp 7.1.6860 and vfs 1.48.89
    does anyone have any ideas why this is happening? nothing seems to work.
    Also, i can't find any error log file. does anyone know where this file for vray is located?
    thanks
    Re: error message
    thanks
    I got that message too.
    Usually I push the render button again, and the render start with no problem..
      Re: error message
      ok, i found my error file log in:
      C:\Documents and Settings\All Users\Application Data\ASGvis\VfS
      then i discovered from the file that there were textures in my materials that it could not find and was timing out. apparently i had a texture that was associated to a component i grabbed from 3D warehouse and the jpg texture got saved by default in a folder embedded somewhere in my documents and settings folder. anyways it didn't like it so i saved the texture in a different spot and it worked. I am wondering if my windows update from last night changed something in that initial document and settings folder which might have caused the problem.
      hope this helps someone else.
