Please let me know!
Has anyone already tested Mac OSX Lion with SKU 8 / Vray 1.49.01????
I'm planning on installing Lion (on a seperate partition) next week. I need to check out Vectorworks but also Sketchup and V-Ray. I'll post the results in this thread.
AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
OSX 10.7.2 (Lion) VR 1.49.01 and DRspawner problem
Yes, but we are having problems with Distributed Rendering. VR 1.49.01 locally works just fine.
Our setup is: iMac 3.4Ghz Quad-Core i7, 16Gb RAM, OSX 10.7.2 (Lion), Sketchup 8 Pro, Vray for Sketchup 1.49.01.
We followed the instructions on how to run the DR script to initiate DRSpawner and it gives us the following errors:
Code:Last login: Wed Jan 11 15:36:22 on ttys000 K81:~ rjh$ /Applications/ASGVIS/RunDRSpawner ; exit; /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:47: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument self.message = messages[errorCode] % msgargs /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:47: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6 self.message = messages[errorCode] % msgargs /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:48: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument Exception.__init__(self, self.message, args) /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:48: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6 Exception.__init__(self, self.message, args) /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument e.message), /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6 e.message), /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:584: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument FtWarning) FtWarning: Catalog resource (file:///usr/local/share/4Suite/default.cat) disabled: Error retrieving resource 'file:///usr/local/share/4Suite/default.cat (/usr/local/share/4Suite/default.cat)': [Errno 2] No such file or directory: '/usr/local/share/4Suite/default.cat' Successfully initialized spawner. Waiting for jobs...
Is it a compatibility problem? (Lion vs. 1.49.01?)
Any help will be appreciated!
Hi, so I have had mixed results, sometimes it works, sometimes not. I cannot find the problem. Sure hope the next version will have a much more stable DR.AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
