Render History
  • Render History
    can you please explained this more in sketchup. I have seen the video in vraymax. but how it works with Vraysketchup.
    http://www.nomeradona.blogspot.com/
    http://www.sketchupvrayresources.blogspot.com/
    http://www.nomeradonaart.blogspot.com/
    Hi Nomer
    Unfortunately we had to disable the History in SU. But basically you can save your sender as a vrayimage directly in the VFB. Then we have some compare tools on the VFB where you can set one render as a A and other as a B an use a slide bar to compare both render. You can also compare the render while you are rendering. These tools is very useful for testing, training, etc. You can also load old images or even 3DS Max images on the VFB.
    Some basic steps.
    1. make a render.
    2. click on the H to open the history windows
    3. click save to save the images.
    to compare
    4 set one image as a A and other as a B- you will see the two images on the VFB
    5. Use the slide to compare the two images
    Please see the attached images.Click image for larger version
      I think I know the concept based on the video tutroial with Vray Max. I just want to know how it work in sketchup. TO clarify at the moment the render history in VRAYSketchup is still disabled right?
        Yes, it is disable at the moment.
