Hi all, first post here!
The notion of halving my render time without buying any new hardware is very enticing one. Especially once AMD releases Threadripper and my current build could sit in the corner as a swarm node only.
I have many questions about Vray swarm, but the main question I have is to do with the licensing:
If you have a full Vray single license, are you able to use swarm? Or do you need to purchase additional licenses for the machines running Swarm?
This is really not clear in any of the documentation, and somewhere on this forum I read somebody saying a Vray license comes with 10 swarm licenses, but then I read somewhere else that you need a Render Node license for each machine running swarm. If you do need to buy additional licenses, I would suggest that Swarm should not be considered a part of Vray, but more it's own product which can be purchased additionally to Vray. The fact that the installer defaults to installing swarm is confusing if additional licenses are required to use it.
And does swarm UI tell you if the node is unlicensed? Or it just doesn't work? I have a server in my house that I installed only swarm on, and in the UI it looks like swarm should be working, but then only my workstation renders buckets. It would be nice if there was somewhere in the Swarm UI that gave feedback about each node's licence status. I think it could save a lot of headaches!
But mostly, I think it would be a good idea to not install Swarm with Vray by default, or at least to add some info into the installer package explaining only to install swarm if you have the necessary license if that is the case.
