VRay 3.6 and VRScene, modify the shaders?
  • VRay 3.6 and VRScene, modify the shaders?
    Hello,
    I would like to know if it is possible to modify the textures of VRScene once imported in SketchUp (from 3DS Max)?
    Thank you!
    Hello, Emilien,
    Currently, this is not possible.
    The only available adjustment to how vrscene components are rendered is the vrscene Lights toggle(https://docs.chaosgroup.com/display/...+%7C+VRayScene).
    Move/rotate/scale transformations also affect the vrscene component render output.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Okay thanks for your quick reply.
      So for the moment I modify in max and I export a VRScene again, then I modify the file path in the VRay Asset Editor / Geometry.
      Have a good day!
