Originally posted by pabloarias
View Post
Problem with displacement
Originally posted by vicke50 View PostThanks, when I apply the material from the outside of the component it work fine except 20 is a bit big for displacement
Pablo Arias
V-Ray Licensed Trainer
Spain
Hi Pablo,
First of all, I've made a rectangle 10mx10m, white face up.
I've imported a bitmap (the roof displacement map in this post) over the white face of rectangle.
Modify this roof material adding the same map to displacement (amount 20 for test)
Group rectangle surface and border lines
Render.... no disp effect
On the other hand there are edge cases in which the displacement might not work when applied to faces.
The thing is that in V-Ray (Core) the displacement can only be assigned to geometries and not to materials while from a user standpoint in SU it's the opposite.
Because of that the following behavior can be observed:
> Every group or component definition in SketchUp becomes a single V-Ray geometric object after you hit the render button (and can only use one displacement)
> If there are multiple materials applied to faces in the same definition V-Ray uses a single Multi-material applied to the definition to distribute the materials
> If any of the face materials (sub materials) has displacement chances are that all the faces in the group might or might not be displaced. There is always one sub material controlling the displacement effect per definition (it's 'randomly' picked)
> If you want to ensure that a specific material controls the displacement of a group you can just apply it to the group. The materials assigned to faces will still take care of the texture placement
To make things more visual I've recorded the following video:
We will do our best to improve the displacement workflow with future updates.
I hope that the information here will help you manage displacement more easily.
Konstantin
I think this has always been the case. You must assign the displacement material to the group and not only to the faces within that group.
Best,AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
