What does it mean when a swarm node's status is listed as Unstable?
Swarm Status - Unstable
"Unstable" server status means that this machine can not access free V-Ray license. If you have enough V-Ray Render Node 3.0 license , then V-Ray license server settings is not input.
Please use the link below in order to change the V-Ray Primary license server information with the ip address of the machine where V-Ray license is available:
https://docs.chaosgroup.com/display/...eConfiguration
https://docs.chaosgroup.com/display/...UP/V-Ray+Swarm
First make sure when you open the following address in your web browser "http://IP_Address:24267/configuration", and in the upper right corner it is "Disabled".
Then please proceed with changing the V-Ray license server information. Please note: "Use system license configuration" should not be checked.
The address should be ip_address:30304, where the ip_address is the address of the machine where V-Ray license server is running and V-Ray licenses activated and available.
The port 30304 should be opened through the firewalls and the antivirus programs.
Let us know if the above suggestion helped you.Last edited by stefan.isakov; 08-01-2018, 07:54 AM.
