V-Ray toolbars won't stick between sessions
  • V-Ray toolbars won't stick between sessions
    Installed V-Ray 3.6 with SketchUp 2018, set up my toolbars, saved as template, chose template from Preferences, saved an Untitled skp file, closed session, but everytime I open a new SketchUp session the V-Ray toolbars are stacked in the viewport and I have to move them manually. Does anyone know how to fix this or am I doing something wrong?
    Thanks in advance,
    Jackson
    SU 2018 + VfSU 4.0
    This is apparently known issue to Chaosgroup. Have been told that they are working on a hotfix.
    https://sketchucation.com/forums/vie...629524#p629524
      I have sent you a private message.
        This happend to me. I repaired the install (with "Run as an administrator") and it seemed to fix it.
          Open a blank sketchup, fix toolbars position and save&close the file..
            Thanks folks, but none of the above fixed the problem.
            /Jackson
            SU 2018 + VfSU 4.0
              Same here. I still notice to this day.
              I must say, it is an intermittent issue, and if I try to reposition the toolbar multiple times, it will eventually stick.
              One thing I have noticed was that SketchUp often, not always hangs and runs (shown in task manager) after closing the windows.
              I do not know if this is related at all.
                UPDATE:
                I have no idea why or how, but suddenly the toolbars are behaving themselves correctly.
                Thanks for the suggestions.
                SU 2018 + VfSU 4.0
                  Also, when you do 'fix' it, any toolbar edits you make after installing/re-installing V-Ray will not stick.
                  Matthew Valero, ASAI
                    One thing I have noticed is that "Chaos Software Ltd. Application Runtime" still runs on your background. You have to "Stop V-Ray Online License Server", and end the task to keep that off even after uninstalling V-Ray for SketchUp.
                    I suppose you have to remove the server and swarm as well.
                    Not necessarily related to this issue, but wasn't sure if it was related.
