V-Ray 3.60.02
  • V-Ray 3.60.02
    Hi everyone,
    There is a new 3.60.02 V-Ray version available for download.
    In this version we've done many fine tweaks, we have improved stability as well as plugin compatibility.
    Additionally, there is a number of new things that you should certainly check out.
    Here's a set of videos demonstrating some of the new possibilities:
    Regards,
    Konstantin
    Was looking forward to this!
    I will definitely try all of those.
    Thanks, team!
      Here are some improvements that are welcome, cool!
        Thanks team +1
          Nice work!
          Matthew Valero, ASAI
            What is the point of "reset viewport texture" that in the right click menu of a material.. It does nothing as i see..
              Perfect, thanks!
                You can go to any texture in a shader and click the small 'eye' icon to see it in the viewport.
                This syncs the selected map with the SketchUp material representation.
                The reset function should set the default (Diffuse) map as a binded texture and will disable the 'eye' icon for all other textures.
                Regards,
                Konstantin
                  Thank you very much..
                    Oops!! I found the toggle. I'm not sure why I couldn't find the advanced camera settings toggle before. As you were Everything else looks pretty good so far.
                      Nice! I like the added functionality of the asset editor's materials section, and the 'right-click auto uvw mapping' UV Tools should come in handy, too.
                      Core i7-8700K @ 5 GHz, Kraken X72, Asus - ROG MAXIMUS X CODE, Trident Z 64 GB @ 3000 MHz, 2x Samsung - 970 Evo, 2x EVGA - GeForce RTX 2080 Ti, Phanteks - Evolv X, SeaSonic - PRIME Ultra Titanium 1000 W, CyberPower - CP1500PFCLCD, 2x BenQ - PD3200Q, 2x Loctek D7L Monitor Arms, Corsair - K70 LUX RGB, 3Dconnexion SpaceMouse, Logitech - G602
                      Windows 10 Pro, Vray 5 for 3DS Max (latest), 3DS Max 2022 (latest), Vray 5 for Sketchup (latest), Sketchup Pro 2021 (latest)
