Hi, is it possible to export sketchup scene using vray-export viewport only rendered area? When i use safe frame it exports with black side lines..
Exporting sketchup viewport limitation
It is currently not possible, you'd need to manually trim the areas outside the safe frame dimension in an image-editing software.
Thank you for pointing this out! Logged a ticket. Will be amended in one of the next updates.
Kind regards,
PeterPeter Chaushev
www.chaos.com
