Flat look
  • Flat look
    I`m trying to achieve a very flat illumination on this plane, so that the center is the same color as the sides. I tried with dome light and rectangle light with no succes.
    Any help would be greatly appreciated.
    Thanks!
    You could use a V-Ray Rectangle Light and enable the 'No Decay' parameter in the 'Options' rollout to produce the desired effect.
      Thanks for the advice. But does not seem to help.
        this is just a dome light with color. And it seems pretty perfect to me. How did you have your domelight configured before?
        should clarify - just a flat color (255 white)for the dome and bump up intensity to suit
          Same result
          The gray from the corners is darker than the gray in the middle.
            You don't have camera vignetting enabled by any chance?
              Yeah, that`s it. I could have spent another day without thinking at vignetting
              Thanks!
                Thanks!
                You're welcome!
