Bump map preview for procedural textures and edit UV placement
  • Bump map preview for procedural textures and edit UV placement
    Hello,
    I was wondering if it is possible to implement a way to preview textures in viewport to preview bump map placement when 'texture placement' 'Repeat U/V' edited? in this screenshot the infinity wall is using bitmap '/materials\Liquid\maps\Water_A_Height_01.jpg' from preset material, 'Waves_A_01_200cm'. I'm editing uv's to give a waterfall effect and would love to be able to preview in viewport with having to trial and error renders. The pool water surface with texture helper showing is 'Waves_Proc_01' preset using 'Noise A'....again, would be great to be able to preview this in viewport.
    Thanks yall!
    GD
    Core i7-8700K @ 5 GHz, Kraken X72, Asus - ROG MAXIMUS X CODE, Trident Z 64 GB @ 3000 MHz, 2x Samsung - 970 Evo, 2x EVGA - GeForce RTX 2080 Ti, Phanteks - Evolv X, SeaSonic - PRIME Ultra Titanium 1000 W, CyberPower - CP1500PFCLCD, 2x BenQ - PD3200Q, 2x Loctek D7L Monitor Arms, Corsair - K70 LUX RGB, 3Dconnexion SpaceMouse, Logitech - G602
    Windows 10 Pro, Vray 5 for 3DS Max (latest), 3DS Max 2022 (latest), Vray 5 for Sketchup (latest), Sketchup Pro 2021 (latest)
    Unfortunately, the SketchUp viewport cannot preview V-Ray procedural textures. To accommodate proper mapping functionality a placeholder texture (texture helper) is automatically assigned.
    You can, however, assign any Bitmap texture as viewport texture by activating the "eye" button below its preview window.
    See also https://docs.chaosgroup.com/display/...ayBRDF-Binding
    Additionally, you can use viewport-render a specified region while editing your scene: https://docs.chaosgroup.com/display/...ering+in+V-Ray
    Keep in mind the overlay opacity can be easily adjusted using 'Ctrl' plus '+' or '-' .
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
