Rendering Black Material
  • Rendering Black Material
    Hey. Im not sure if this should happen when rendering a Black Plastic Material (downloaded from here the name is Plastic_Dark.vismat) I said its black because I changed the Diffuse color to total black instead of the original dark gray.
    Also I tried creating a new material by starting with the SU material editor:
    1.- Chose from the colors palette a Total Black
    2.-Then in VfSu selected this "material" and started to give Reflection and Glossines values (.6)
    exactly the same as the Plastic_Dark.vismat values.
    Then render it and it was the same. Then decreased the values to (.1), render it, and there was a little change, the material seemed darker but without shine obviously.
    I was wondering if this has to be with the settings for Rendering or should I enclose everything in a box
    I will appreciate any help. Thanks.
    I'm using SU Pro 7
    VfSU 1.05.30
    Windows Vista 64-bit
    4.00 GB Ram
    Re: Rendering Black Material
    the color is ignored if a texture is set
    Devin Kendig
    Developer
    Chaos Group
      I think dkendig is right..
      For any Sketchup related issue please visit: www.sketchup4architect.com
        and i keep answering them like a robot O:
        Maybe i should do a FAQ stickie for Vegas like the WMM forum has?
        but then again Im lazy O.o
        bulk email verifier
