New Build 4.30.00
  • New Build 4.30.00
    Hi, guys
    New build is up!! You can download V-Ray for Unreal, update 2.3 here: Download
    Here is the changelog for version 4.30.00:
    - Added support for Unreal Engine 4.23 (Recommended use after engine update to 4.23.01)
    - Added cancel button when importing vrscene
    - Added automatic saving of rendered still images in Unreal viewport
    - Added support for import automation of vrscene via python script
    - Added support for Temperature parameter in native Unreal lights
    - Added V-Ray for Unreal update notifier
    - Improved support for Unreal expressions - RotateAboutAxis
    - Improved speed of processing and storing of rendered lightmap atlases
    - Fixed VRay CUDA GPU Device Select missing from UI
    - Fixed Actors with same ID Names not exporting correctly
    - Fixed incorrect render elements settings when rendering sequencer animation
    - Fixed crash when closing Unreal while rendering
    - Fixed crash when Render Element Light Select has listed lights that are hidden in the level
    - Fixed missing Shader Balls preview in Content Browser for V-Ray Materials
    - Fixed V-Ray Settings are empty when Project Startup Map is set to None
    - Updated Online License Server in installer to 5.2.3
    Be sure to check the V-Ray for Unreal documentation page for details about the new features and improvements.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
