New Build 4.30.01
  • New Build 4.30.01
    Hi, guys
    New build is up!! You can download V-Ray for Unreal, update 2.4 here: Download
    Here is the changelog for version 4.30.01:
    - Improved speed when using Unreal materials in render and lightbake
    - Improved visual quality of shadows when lightbaking
    - Improved support for Unreal expressions - SetMaterialAttributes, GetMaterialAttributes
    - Added Near Clip Plane functionality to VRayPhysicalCamera
    - Added V-Ray Icons in Modes panel to V-Ray Assets
    - Fixed crash when switching levels while rendering
    - Fixed crash when closing Unreal Editor while rendering
    - Fixed crash when rebaking actors and loading lightmaps
    Be sure to check the V-Ray for Unreal documentation page for details about the new features and improvements.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
    This new build seems much faster. Good job.
      VFB renders work fine with latest nvidia drivers. But viewport IPR renders abort and require driver 436.30. This used to be just a warning, but is now a requirement. Is this an error, or am I now required to roll back to 436.30 to use vray for unreal?
        Hi Nerva,
        This should be still a warning. Can you please send some screenshots or logs of the results you are getting?
        Alexander
        Alexander Atanasov
        Chaos
          The render does fire off, but never renders in the viewport, and the following error appears in the message log. VFB works fine.
            Hi Nerva,
            From the screenshot I can see that you are not using the latest NVidia driver (441.20). Please update to latest version an see if the issue continues.
            Alexander
            Alexander Atanasov
            Chaos
