Bake looks NOTHING like render.
  • Bake looks NOTHING like render.
    I think the title speaks for itself. What is going wrong?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
    Hi, Macker
    What is you lighting setup? I see a couple of IES lights and rectangle lights but in the render there is white outside so I would presume a dome light. The black/dark parts of the tiles look like bad or no lightmap UVs. Please give a bit more information.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hi Aleksander,
      Yes there is a plain white dome light outside. The tiles are looking bad because of the lightmap UV's, which I've fixed now. I don't understand why the windows have turned black - in VRay they are just black diffuse, White reflection & refraction.
      Also without wanting to muddy the waters - is there a certain amount of padding I should be using when unwrapping UV's?
      Kind regards,
      Chris
        Hi, Chris
        Is there a certain amount of padding I should be using when unwrapping UV's
        A good practice is to have a couple of pixels padding around the UV shells, maybe around 2 to 5 pixels should be OK.
        Can you please try a lightbake without the IES light, because there is a little issue with them and maybe they cause the dramatic lighting mis-match. Also I would suggest to put a Reflection capture in the scene. That helps with the reflections and sometimes brightens the lighting.
        Alexander
        Alexander Atanasov
        Chaos
          Will do. What about the black glass windows? Why should they be like that/not letting light through?
          The setup I have on them in VRay/Max is as simple as it can be.
            Nothing comes to mind. When I try to do the same with refractive material it works fine. There is currently a bug that we are aware of with the shadows after light bake to be much brighter than they should and we are addressing that issue.
            Can you send a vrscene with only the window and the glass to check if we can reproduce it here?
            Regards,
            Alexander
            Alexander Atanasov
            Chaos
              A lot of the issues I've been experiencing are down to having not flattened the lightmap UV's, etc. I've fixed a lot of it now, but the black glass remains.
              Here's the room with just the windows & walls: https://we.tl/t-RfI0VWDPwu
                Hi, Chris
                I've looked at the file you sent. I imported the vrscene, added a dome light and just hit bake and it worked fine.
                Maybe there is something inside the window that you didn't export? Can you check that there is nothing obstructing the glass. If you can't find anything you can send the whole project at support@chaosgroup.com and we will take a look to find the problem.
                Alexander
                Alexander Atanasov
                Chaos
                  That is so odd! When I exported (my) .vrscene I exported everything. Maybe I'll just delete the windows and just re-import them - is there a particular workflow for this?
                  I've just imported the scene that I sent you and still have the same issue; so it must be local to me?
                    The current workflow is the following:
                    - delete the the assets you want to reimport both in the level and in the content browser (this is also valid for materials if you what to reimport them. If the the materials are not deleted from he content browser they will be assigned to the newly imported meshes automatically)
                    - import the newly created .vrscene - V-Ray will check for similar assets and will skip the ones that are already in the Content Browser and will import the new ones.
                    Alexander Atanasov
                    Chaos
                      Hey Alexander,
                      is there still a problem with baking lights in a scene with IES lightprofiles? Cause I tried to bake a scene in Unreal with some IES lights and the spots turned black and a message with "could not load IES profiles" (or similiar to this) came up.
                      So what is the current status there?
                      Simeon
