What do you recommend to use, when you want to make brightness, contrast, gamma adjustments on an HDRI map and using the map to illuminate the scene?
If I use VrayEnvironment, I can't make any of those adjustments.
If I am going to use the VrayLightDome, I can also load the .hdri file.. but making gamma or contrast adjustments.. I can't find that option.
Anything you can recommend?
Thanks a lot!
Thanks a lot!
