Can you actually use the VrayScans for Unreal?
Vray Scans
Tags: None
Hi, Bernhard
Importing of VRscans is not supported at the moment. If you import a scene that has VRscanned materials they will import pink. However you can use the "Render material from .vrscene" option on the material instance when you render you will see the VRscanned material.
AlexanderAlexander Atanasov
V-Ray for Unreal & Chaos Vantage QA
Chaos
