installation issue
  • installation issue
    Installation does not appear in the plug-in.
    Is it normal to turn it off as soon as you click "Done"?
    It's the same if you delete it in multiple versions and reinstall it. Other computers are the same goes for other computers.
    Hi vldkaak,
    After installation the V-Ray plugin should be enabled manually(it is not enabled by default) in the Plugins window inside UE. If it is not appearing inside then either it is not installed for this specific version or something went wrong during installation. Can you please send the install.log located here: "C:\Program Files\Chaos Group\V-Ray\Unreal\uninstall"?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
