Enhance vrscene support from V-Ray Next SketchUp / Rhino.
  • Enhance vrscene support from V-Ray Next SketchUp / Rhino.
    Enhance vrscene support from V-Ray Next SketchUp and Rhino.
    Is it possible now including UV?
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hi, flat
    What do you mean by "Is it possible now including UV?" If there are UVs on the mesh in SketchUp / Rhino then they should be imported. Please give more details.
    Alexander
    Alexander Atanasov
    Chaos
      SketchUp can not create UVs suitable for light map bakes.
      Therefore, to generate a lightmap with SketchUp vrscene, it is necessary to generate a lightmap UV on the V-Ray side.
      Does the current V-Ray for Unreal solve it?
      oakcorp.net
      v-ray.jp
        Hi, flat
        Unfortunately no, V-Ray for Unreal doesn't create UVs. This problem with lack of proper UVs is concerning Sketchup, Rhino and Revit and we are aware of the issue and researching the matter.
        Alexander
        Alexander Atanasov
        Chaos
