V-Ray GPU using Turing raytracing hardware (RT Core)
  • V-Ray GPU using Turing raytracing hardware (RT Core)
    https://youtu.be/yVflNdzmKjg
    This demo is running on experimental V-Ray GPU build with a pre-release Quadro RTX 6000 and driver, using RT Cores.
    This makes V-Ray GPU the first commercially available production GPU render that uses the hardware accelerated raytracing in Turing.
    All current V-Ray GPU versions support the NVIDIA Turing architecture natively.
    The new raytracing hardware in the Turing architecture (RT Core) requries experimental V-Ray GPU build, which is available on demand during the Turing pre-release period.
    Production scene courtesy of Dabarti. No denoising used.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
    Originally posted by savage309 View Post
    The new raytracing hardware in the Turing architecture (RT Core) requries experimental V-Ray GPU build, which is available on demand[...]
    Hi Blago,
    Is there a sense of how much the raytracing tech speeds up a typical scene? I realize ‘typical’ is vague, but it’s hard to gauge from the YouTube example what kind of improvement we’re looking at over, say, a 1080 Ti.
    Thanks!
    Daniel
      Not seen any bench marks for it yet: https://benchmark.chaosgroup.com .... The number 1 ranked GPU score there is cryptic to me however.
      "AMD A8-7650K Radeon R7, 10 Compute Cores 4C+6G x4, Spectre 2559MB"
      What the heck is that?
      WerT
      www.dvstudios.com.au
        werticus Seems wrong to me. Will investigate. Thanks for reporting it
        danio It's really early to say. Best to wait while the cards are out and thoroughly benchmarked.
        Alexander Soklev | Team Lead | V-Ray GPU
          Originally posted by danio View Post
          Hi Blago,
          Thanks!
          Daniel
          We have only pre-release hardware and drivers, so it is very hard to say.
          Best,
          Blago.
          V-Ray fan.
          RTX ON
            Blago, two questions on Lavina and some of the videos released. It seems as if Optix would be the implementation for professionals, no? If so, why was Lavina implemented in DXR?
            The other thing I was thinking about, would it be possible to implement your internal .vrscene viewer that Vlado used in his presentation as an Activshade in the 3ds Max interface?
              When we started looking into Lavina back in February, OptiX was not exactly where we needed it to be.
              That has certainly come up as a possibility, but it's a bit early to say. We'll see.
                Optix is nvidia only right? Be better if they support AMD too.
                WerT
                  OptiX is NVidia only, yes. I don't think it will ever support AMD. On the other hand, AMD may choose to support DXR and the raytracing extensions for Vulkan, but I don't know if these are enough for a production renderer (f.e. DXR does not support motion blur, which we kind of need ; not sure about Vulkan though)
                    Seen a vray bench on the 2080ti
                    it gets 52seconds vs 69seconds for the 1080ti.
                    Plain 2080 gets 70 seconds.
                    WerT
                      So basically none of them are worth buying over 10 series until Vray adds support for RT cores.
                      Aleksandar Mitov
                      www.renarvisuals.com
                      office@renarvisuals.com
                      AMD Ryzen 9 9950X 16-core
                      96GB DDR5
                      GeForce RTX 3090 24GB + GPU Driver 566.14
                        yeah it would be nice is chaos chimed in with some performance opinions now that embargo is lifted.
                        WerT
                          Performance numbers can be shared only if they are made with official and not pre-release hardware. As soon as we have such, we will share them.
                          Best,
                          Blago.
                          V-Ray fan.
                          RTX ON
                            Do you know guys if NVlink will allow memory sharing through NVlink on consumer grade cards (2080/2080 TI)?
                              AFAIK - yes, it should allow for memory to be shared both on consumer and pro Turing GPUs with V-Ray GPU, *but* we haven't tested yet and we will make a post once we do.
                              Best,
                              Blago.
                              V-Ray fan.
                              RTX ON
