VRay GPU Roadmap?
  • VRay GPU Roadmap?
    Hi there,
    We are a studio that has primarily used the CPU Production Renderer for all of our work. Over the last week we have been testing the CUDA Renderer with 2x 2080 TI's with a view to looking at if rendering on GPU's would offer any benefits to us.
    Our findings are somewhat overly simplified but generally the following;
    Rendering on the GPU's is almost twice as fast as on the CPU (comparing 2x 2080 TI's to 2x Xeon E5-2699 v3's) but comes with the compromise of less features, some of which can be deemed an integral part of existing pipeline / workflows.
    It would be useful to know what the roadmap for the GPU Renderer looks like and if we are going to get to a point where we have most, if not all, of the same features on both renderers?
    Any information would be appreciated.
    Thank you
    Second this. Would love to know which features to expect to be ported to GPU and some sort of timeline
      For the moment we are focused on several big features: RTX support, out-of-core geometry, OSL support and deep output. All of them require substantial amount of effort, but I’m glad that there is very good progress. We will show more at Siggraph in about a month or so.
      Beyond that, if there are any features that you find missing for your workflow, please let us know so that we can priotitize them.
        So there is no road map at all?
        is there a list of things you want to implement besides what you are working on right now?
        it would be good to know, so people don't separately request and nag all the time (including me)
        Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
        www.AddYourLight.com
        Always looking to learn, become better and serve better.
          Of course we have a very long list of things that we want to implement, but I specifically want you to hear from you - it helps a lot with prioritizing stuff.
          I'm usually very careful about posting future plans and only post about things that I'm pretty sure about; on the one hand I don't want to overpromise, but on the other hand people get discouraged if they don't see their favorite feature at the top of the list. That's why I would prefer to hear your feedback and internally adjust the plans accordingly.
            Hey Vlado,
            Thanks for the response, this makes sense.
            For us, a few of the key features of V-Ray Production, that we rely upon for most of our projects are as follows;
            1. Material Select Render Elements
            2. Trace Sets Support
            3. Full Cryptomatte support
            4. VRayScannedMtl support
            5. Dome Camera support
            6. Object Select Render Element support
            7. Total Light Render Element support
            That's all I can think of from the top of my head. Of course, ultimately our preference would be a like for like render engine as much as is possible. Having the real ability to use either CPU or GPU would be great
            Thank you
              For the moment we are focused on several big features: RTX support...
              I understand RTX support will introduce super significant improvement on Interactive render? Or will the just be used for "regular" render?
                Hey Vlado,
                Just saw your reply. Thanks for giving us some insight into the thinking behind the dev process. RTX support and out-of-core geo make a lot of sense as a high priority.
                Biggies for me for GPU support in no particular order (though I imagine I'm in the minority here):
                - Vray Clipper full support including mesh clipping - I love this tool and I use it a lot. I'm guessing there might be difficulty with precision on the Geforce cards vs Quadro?
                This would also help a lot with Phoenix FD workflow as the clipper seems like its almost essential when working with liquids in containers
                - FastSSS material - support for raytraced (solid) and raytraced (refractive)
                - Phoenix particle shader support to enable foam/splash etc
                - a like-for-like render engine as brobins mentioned would be amazing though I imagine that would be difficult this far down the line. At the least a closer match between the look of bump/normal maps when switching between CPU and GPU, it often looks like they're at a completely different scale.
                - Vray environment fog when assigned to meshes
                joey145 my understanding is that RTX support will help with both IPR and 'regular' render. Chaos Group made a great blog post that I've attached explaining the ways RTX will help with the rendering process
                With the big announcement of new GPU ray-tracing hardware, Vlado explains what this breakthrough means for the future of rendering.
                  Refraction affect channel functionality.
                  The ability to exclude geometry from the ExtraTex pass.
                  As mentioned above, bump maps between Next engines.
                  A standard material library like corona and other engines would be helpful, I'm not sure why this hasn't been done before but would be very helpful.
                  Lightmixer! Would be great!
                    For us currently its:
                    - Full Phoenix particle shader support to enable foam/splash (Instead of the current VRay particle workaround)
                    - Bump map standardization between CPU and GPU
                    - Custom mapped density in VRayEnvironmentFog
                    - VRayDistanceTex
                      I'd like to see that I tested yesterday with only one RTX2080, and the ocean scene render was extremely fast! I would love to be able to render out the foam and splash also on GPU.
                      www.mirage-cg.com
                        full vraydistancetex support
                        Surrealismo
                        https://www.facebook.com/surrrealismo
                          Is the new out of core tech already in 4.12.01 Maya Version?
                          Or on the nightlies? Id like to play with.
                          https://linktr.ee/cg_oglu
                          Ryzen 5950, Geforce 3060, 128GB ram
                            -All the nice features vray cpu has to offer to save ram.
                            German guy, sorry for my English.
                            • #15
                              I would add the VrayMatteShadow render element to this list. I still use kick out 2 AO passes (one at 2 inches/5cm radius and another at 1 foot/30cm) and I use the Matte Shadow element as a mask so that I only get AO in the shadows. The VrayShadows element is not a viable replacement because I am doing a great deal of solid stainless steel renders and the lighting/shadow data is very limited because metal has no diffuse values.
                              Thank you very much and best regards,
                              Lee
